The answer to your question may already be available here! Check this list as we will be updating it regularly ![]()
Support Questions:
- GMMK PRO over lube problems
- GMMK PRO screw size + where to buy replacement screws
- GMMK PRO keys not working
- GMMK PRO shortcuts
- GMMK PRO PCB clip broken
- GMMK PRO heat tolerance with heated desk mat
- Switch out GMMK PRO for newer batch GMMK PRO
- RGB at night/in the dark for GMMK PRO
- USB keeps failing on GMMK PRO
- Durock v2’s fitting in the GMMK PRO
- Tolerances in the GMMK PRO
- Anyone still having issues with CORE/firmware?
- Double key presses/chattering?
- GMMK PRO lights not dimming with inactivity
- HELP! Stripped screw
- Anyone still having issues with the screws being too tight?
- Fn Key Binding GMMK PRO
- Polycarbonate plate warping PCB
- GMMK PRO knob mute not working
- Keys sticking
- How to change lighting color via hotkeys
- Lights flashing on sides of keyboard
Product Update Questions:
