So I just received my new GMMK PRO and so far so good. Overall really pleased with it.
However going to a 75% keyboard, there’s a few things I miss.
Mainly my HOME key. I’ve been trying to use Glorious Core to create a shortcut, so when I hold down CTRL for example and press the END key, it’s actually going to be the HOME key instead. Does anyone know if this is possible?
I know QMK or VIA is supposed to be able to do this, but, I’d prefer to not have too many different types of software installed.
I’m not entirely sure how it would be done with Core (I use QMK/VIA), but typically it is done through the layers, so you might need to set it to be Fn+End. Alternatively, you can just make one of the keys a home key. I have Delete in the top right, then the four on the right are Home, Pg Up, Pg Dn, End.
Yeah not 100% sure why we have both layers and profiles. I do want to keep my default layout keys and just be able to CTRL+END to HOME. It seems like such an obvious thing for a 75% keyboard.
Like
Choose what combination of keys you want e.g SHIFT+1
Choose action e.g open a website
I’m surprised there isn’t a way to do that in the CORE software ? Unless I’m missing a thing.
