Does anyone know what screws does the gmmk pro use? are they just normal m2 screws as one of the screws that is on the board has been stripped and im lookign to replace it
Apologies, just saw this question! Checking on an answer for you now and will get back to you ASAP
EDIT: Looks like you were correct, they are m2 screws
