I am just wondering what the GMMK Pros keys look like in low light/dark with the RGB (non Aura keycaps)
Welcome to the forum!
Are you looking for what they look like with backlit caps, or with regular?
thinking of GPBT keycaps in particular, or just any keycaps?
yeah the GPBT keycaps.
I can take a pic once I get home of my board with all my lights off. I’m using MT3 caps right now, but I can through some PBT Cherry profile caps on for a picture too!
not backlit just regular. Just want to make sure i can see the keys a little. I know this is small thing but just want to make sure.
Might just be me but there’s something really satisfying about a nice white keycap set.
I love the white so much, I’m thinking about buying the gold cable and making the rgb a yellow as well.
@lbris
that sounds
I will say I got the rain forest GPBT caps with my GMMK Pro and in the dark I couldn’t see the legends at all. Not like it shouldn’t be expected with dark legends on dark caps, but it was definitely hard to read if you’re trying to
I have found when playing games in a dark room it’s difficult to see the legends. I simply orient with the texture on the F key and I’m good to go. But I would say this kind of issue is universal.
Thanks this is what I was after. Hopefully they release south facing backlit keycaps.
