I have a heated desk mat that I like to use on particularly chilly mornings- does anyone know at what temperature would I be in danger of damaging my GMMK Pro?
A heated desk mat? Interesting… I doubt that it’s getting hot enough to melt plastic, so you should be fine. With how thick the bottom half of the GMMK Pro case is it would probably act like a heat sink and dissipate the heat fairly quick.
I’m with @Pseudo on this one. I used a heated desk mat for a bit and it didn’t give me any issues. It doesn’t get crazy hot so you should be good to go.
Thank you both!
