Hey there! There’s actually one topic in the main post listed as “Squeaky mouse wheel?” that sounds like the same issue as your issue. I’d suggest reaching out to our support team and they can walk you through lubing the mouse wheel
You have to hold this combination down for a bit for it to factory reset, I don’t think you will be holding them down for long enough to factory reset while playing a game
Wireless can be used as USB device? And by that I mean if the PC is going to recognize it as an USB device, NOT charging it through USB but connected as a wireless device.
