So ive been using my gmmk pro for about 2 hours in total now and my spacebar is deciding to stick a little bit. i havent done any mods and was wondering how to fix it or if i should just order some durocks or something?
and if anyone else has questions they can also post here.
The usual culprit is overlubed stabs. I can’t tell which stabs are in this build, but I am definitely seeing lube in the last picture fairly easily. Did you lube them, or did they come pre-lubed in the board?
I don’t own a GMMK Pro, so I have no idea what they come with stock.
I was going to say exactly what @SentientTD said, over lubed is most likely the culprit
Alexotos is amazing. I try and catch his Twitch streams every time he is doing a build, I just watched him last night build the Mode Eighty with Boba U4 switches and GMK Modo, he made it a silent keyboard and it was really nice
some people have preferences and like some latency when they type if you are someone who games competitively make the latency as low as possible. polling rate is how many times the keyboard communicates with your pc. can use up a bit of RAM but turning that shit up with the gmmk pro doesnt really affect my pc but to be fair I have a pretty decent one
You can try updating the firmware and or restarting your PC otherwise, I’m not too sure maybe reach out to support. Make sure you hit Save when you make a change to.
