Curious if anyone has a suggestion on this issue:
The GMMK NumPad seems to “sleep” after 10-20min of non-use. I have it on a wired connection (BT is off). The first keystroke after sleep wakes up the device but it does not register the keypress. This creates a (slightly) annoying requirement to hit a key twice to register the input. Has anyone else encountered this issue? Any workarounds?
Thanks!
I stumbled upon my own answer - it’s not really intuitive but turning off the inactivity counter for lighting in Glorious Core seems to keep the numpad active. Image: https://imgur.com/a/SBUob1i
Hope this helps anyone else who has been frustrated by this issue.
This Frustratingly solves the issue, but creates the additional problem of killing the battery life on my Model D Wireless. Does anyone know if there is a way to force that setting to be device specific?
