Glorious Core: Unable to bind key + function to multimedia control
I cannot find a way to bind FN + L to lower Multimedia Volume in Glorious Core.
I modified the L key to include FN + L function from the Single Key / Combination Key tab, so the keyboard displays L Single Key + L / FN + L, hit save; scrolled down to the Multimedia tab and selected Volume Down, hit save; this rewrites the keyboard display from L Single Key / FN + L to L / Multimedia Volume Down.
This makes the L key into a Multimedia Volume button, when used it lowers the volume down; when pressing FN + L, the keyboard recognizes it as a basic keystroke L. This is exactly what I am looking for, except its behavior is reversed.
What am I doing wrong?
The last time I checked, you can’t bind the fn layer in Core.
To me it looks like the first time you modified “L” to input fn+L (like a macro)
And the second time you set L to input vol Down.
When you are pressing the actual fn+l, it will pass down through the layers, and if glorious hasn’t specified a fn+L in firmware, will Bypass right to L.
After messing around with Glorious Core a bit more, I don’t see an option to bind FN + to multimedia. To say that I am disappointed is an understatement.
I’ll e-mail support for further assistance, and if I get a resolution, I will update the thread.
I dragged my feet drastically in trying to do this and I am encountering the exact same issue. I would like to remap the multimedia functions to the function layer. I’m hoping that this is addressed in the relative near future. The multimedia keys are mapped to other FN + buttons, it’s weird we can’t do the same thing.
The inability to do this genuinely breaks the user experience. Had I known about this limitation, I’d have bought literally any other keyboard.
We’re years into Glorious Core and GMMK keyboards and yet they haven’t released basic functionality to map FN+something to do things. Absurd.
After two years of using the product, I have to say, the same issue persists with the Glorious Core software, and it’s disappointing. Despite numerous firmware updates, it’s still impossible to bind FN + L to lower multimedia volume—something that should be a basic feature in any advanced keyboard software. The fact that this issue still hasn’t been addressed is frankly embarrassing and unacceptable.
I had hoped that by now, Glorious would have invested in the necessary research and development to improve their firmware. Other brands, especially those utilizing open-source solutions, have surpassed Glorious in terms of customization and functionality. The lack of progress here is extremely frustrating.
I did, however, find a solution: I stopped using Glorious products. Until they fix their software and provide the level of functionality expected in 2024, I won’t be returning to their keyboards. There are simply too many other options on the market that deliver on what Glorious continues to fail at.
