Hello All,
I just got myself a GMMK Numpad! I’d like to use it both at work and home and was wondering if anyone had any recommendations on a carrying case for it?
Thank you!
JJ
Hello All,
Thank you!
JJ
I was doing some keyboard organization this weekend and had the same thought since it’s the only one I have without a case. I’m subbing to this thread in case anyone has a recommendation. I’ll also look around as well to see what I can find. ![]()
The best I could find is something that is designed for an external hard drive like this one. It is not perfect but is something you can utilize for the numpad it would be protected.
This site is offering a carrying case but I’m not 100% sure it would fit the Glorious one and doesn’t look to provide much protection.
I mean… it looks like that carrying case was designed for the numpad! I had to go back and read to make sure you didn’t buy some premade solution. Great work on that cutout. Looks amazing.
