So I installed GSV2s in my GMMK2 along with 65g Zilent v2 switches. I started installing keycaps and got to the first one with stabs. I put the keycap on and it would stick. I found that the stabs are lower than the switches so when a keycap is installed, it gets stuck in the lower position of the stabs.
I know this may look like something is wrong, but this is how they should be as the stabs do not have springs pushing them up as the switches do so, they are currently in the lowered position while the switches are in the upper position. Once you put the keycaps on them the switches will push the stabs up. It would be more worrying if the stabs were in the upper position as that means they are likely over-lubed and getting stuck in the upper position.
Hmmmm… The way they are now though; when I press any of the keys that have a GSV2 stab, they don’t go back up all the way. I have to grab the keycap and tug it upwards to get the key back up.
Did you lube the stabs? And it so, how much? I found these need a very light coating. First try for me I over did it and needed to wash and start over.
I just spent the last 45 minutes taking the whole thing apart. Damaged half of the Zilents in the process (those cheap U-shaped switch pullers really suck) so this is becoming an expensive headache.
I didn’t see anything wrong with the GSV2 so I’m not sure at this point. I’ll probably end up returning the GSV2 and the GMMK2.
Just to verify, the the piece of plastic the wire goes in oriented correctly? I don’t want to assume anything, just trying to explore all options.
The stab should move up and down seamlessly if you pull it and it gets close to the height od the top of the switch. If isn’t moving up and down without great effort I’m wondering if that could be the culprit.
Yes it’s oriented properly. I searched for as many GSV2 reviews, articles and videos I could find to make sure I had them assembled correctly and seated in the correct orientation, etc…
This happened to me when I was testing them I just figured I over lubed them. I actually love those lil metal switch pullers I’ve never had any problems damaging switches.
I’ve had this happen to me before on certain builds. As others have suggested, it could be any number of things. I’ve typically found this to be a tolerance issue, usually with the keycaps, or with something being “overtightened”. Try loosening the screws a touch on the top aluminum plate around the stabs. If that doesn’t work I’ve also found that loosening the screws of the stab itself on the underside of the PCB can help resolve this sticking issue as well.
I just checked my GMMK Pro with Cherry Clip-ins (GSV2 on the way) and my stabs sit about this low as well. I’m not sure that the “lowness” is the issue. Like @Donny said its possible you need to loosen the screws or make sure they seated flat onto the PCB.
Not much I can add to help your stab situation, but I would like to say that Zeal v2 housings are made of some material that is much more fragile than other switches. Damaged my Zealios v2 using a proper switch puller.
You need to make sure the wire is sitting in the lower chamber of the stem. Sometimes they won’t rise because the stem is backwards or because the small wire arms are in the top hole
I had a similar issue when I rebuilt my Keychron Q3 recently. The stabs screwed in and everything looked alright, but the keys would stay down when pressed. It turned out the stabs were not mounted properly. The plastic clip which holds the housing onto the board was not flush. Once I reseated them properly, all was well. It could be something worth checking if none of the other suggested remedies have helped.
