Does anyone have a fix for the volume knob skipping increments? Usually each turn in the notch is a 2 volume increase. But about half the time it doesn’t register on screen, then with the next turn it jumps up 4 volume levels.
A minor detail but it bugs me. Anyone else have or fixed this?
Cheers!
This is a Windows problem, unfortunately.
Do you know any specifics of the problem?
My last keyboard had a knob but that never happened.
It’s just the default behavior in Windows. Even if you put QMK on the keyboard, it’ll do the same thing. Volume buttons also do it. So maybe your other keyboard did something special, but I’ve yet to see one that does it that way.
Ok, cheers! Thanks for the info, much appreciated!
