What do you use to clean your mouse? Microfiber cloth? Cotton swab? Any solutions? How do you get inside each honeycomb? How do you get in between the side RGB or side buttons? How do you clean your mouse wheel?
I recommend you give this video on how to clean the Model O a watch!
I’ve been using a micro fiber and an electronic air duster with the bristle attachment. For the scroll wheel I have those micro applicator brushes that I dip in isopropyl alcohol and clean the wheel that way.
Rubbing alcohol (or nail polish remover) and q-tips are what I use. They’re readily available.
Personally for all the dirt and grime my mouse has it’s actually really hard to clean, like the cathair in my mouse just won’t come out (don’t question how it got in there in the first place).
so I actually ended up buying that pen thing before i watched this video! haha
i feel you, I vacuum my deskpad every other day because of my cat. my mouse is currently filled with cat hair lmao. although i didn’t realize you could remove the back so easily so i’m going to try to vacuum it out once my nails grow back cus i just cut them
Is this your way of low-key flexing your psychic abilities?
Hahaha yes and I already knew you were going to say that
