So I have the GMMK and the model D is there a way to sync the RGB between the two glorious devices?
Another out there question can you sync RGB with other manufacturer’s?
The fact that my mouse and keyboard are slightly out of sync drives be a bit crazy.
Thanks for the help in advance!
Syl
2
Though its third party, you can probably sync them through SignalRGB?
Though you’re pretty limited with the free version.
JrEtwon
3
I wouldn’t say the free version is that limited, but overall your device being able to work with it is very hit or miss
i tried signal RGB but it doesn’t recognize my GMMK pro. it seems I have to delete Glorious Core. it only recognizes my model o
ice
5
