That color coordination is on point @Kpurry
something very satisfying to me when EVERYTHING matchesâŚlove it
Have my Batman metal board as hubby calls it. With banana split linear switches, polycarbonate plate and grey GMMK keycaps most favorite board right now!
Ohhh I loveee the banana splits ![]()
finally posting here after looking at all the dope builds from the community! ![]()
i started out with kalih silver switches with arctic white keycaps and nebula coiled cable. with a bringhockeyback desk mat that was way too small but i had to buy it because hockey
then switched to kinetic labs octopus keycaps around august last year. i just got my white frame and knob yesterday and iâm obsessed with it! apollo topo desk mat cause purple is my favorite color ![]()
There are not enough purple boards! This keycap + mat combo is
perfect
That color scheme though
thank you!
it took me a bit to end up with this build, but i think itâs gonna stay this way. unless some other purple keycaps pop out at me lol
Iâve posted some QMK builds, figured I should at least show off my main setup!
The caps are Akko ASA Carbon Retroâs, with Gateron Brownâs underneath. I donât have a fancy USB cable.
Mods:
Howieâs Hockey Tape Mod(I tried masking tape and wasnât a fan)
Removed internal foam, replaced with PE
Beefed up the board gaskets on all sides with extraâs from the box.
Put it all together without overtightening the screws and loosing all the bounce!
@Obr1en welcome to the guild!âŚlove the setup! The tangerines are one of my favorite switches ![]()
This set up is so slick!! I love it. Welcome to the Guild ![]()
Trying out some Azure Blue Dragon switches in the GMMK Pro. They are my favorite tactile now! Iâve tried all the plates (brass, poly, FR4) and over and over, I keep going back to the Aluminum plate. It seems to give the deeper sound, whereas brass seems to bring a bit of ping to the switches Iâve tried. Poly, which usually is deeper, just isnât in the GMMK pro. I feel the FR4 is in between the Poly and Alum.
Voila, sound test!
Azure Blue Dragon switchesâŚ
They are on sale on the GoPolar site, donât go there and donât buy them
Man this looks good, I love the arrow keys.
Ohhh that came out good
âŚwelcome to the guild!
All those accent keys are amazing. The enter, backspace, space bar⌠all amazing.
lol keycaps are more expensive than the board ![]()
Looks amazing though!
