Hey, I am relatively short and my monitor on its current stand (the one it came with) is a good eye-level height for me. I really like the looks of monitor risers, but they make the monitor too tall for me, so I was wondering if anyone knew of any short ones, so I don’t strain my neck looking up all day. Just maybe off the ground enough for a phone, and some cables.
For anyone who is confused, this is a Moniter Riser :
Do you have the ability to mount monitor arms? There are some pretty good, inexpensive ones out there and that would allow you to set the ideal height level for you.
I’ve looked at grovemade in the past and its quite out of my price range, however clamped moniter arms may be the route I take.
FYI : That’s an image I found on google, not my setup
