I’ve been lookin at various boards and thinking about getting one, though can someone please clarify if I am right with my understanding of the RGB ? There are mentioned modes that can be chosen between with a button press, and brightness and speed of pattern can be changed, but is there any custom configuration available ? Ie can you map certain colours to specific keys, either static or with patterns of colours ? As I currrently have different profiles for different games/programmes where the keys are coloured according to their function, is that something i can recreate with any Epomaker boards ?
Yes, as long as your utilizing Glorious Core Software you should be able to change all your key colors individually, as well as save their profile. Although I’m not sure about Epomaker, those aren’t a part of Glorious.
