hello, i have a problem with glorious core software,
when i try to change color rgb effect or color and press on save, these effect-color are not saved.
the version of software is a 1.0.24
any solution?
I don’t have the software 100% figured out yet, but make sure that you’re on the correct layer of the lighting when you’re making the changes. There are three diamond icons next to the image of the keyboard, and if you click on that, it changes your current layer.
Sorry, I’m at work right now and I can’t recall exactly where it’s at. I can post a screenshot when I get home in a few hours, unless someone else is able to help you in the meantime.
Like I said, I’m definitely not an expert. There are a few things I was trying to setup with my lighting that I couldn’t quite figure out either.
Hey there! Not sure why it wouldn’t be saving your input, may be worth chatting with our support team. We have live chat on our site now that should be able to get you a quick response!
