What is your preferred way to set up your keyboard RGB lighting?
- One solid color
- Dynamic color pattern (i.e. breathing, wave)
- Custom per key colors
- Off
- Other
0 voters
0 voters
I switch between all of them I really enjoy reactive-type tho. Currently, I’m using “Fast Run Without Trace”
Ah fair point, let me add reactive to the list of options!
*edit: well dang, it doesn’t let you update poll options after the first 5 mins the poll is live. The more you know I guess haha.
Let’s just consider it other or drop a like on my comment
I’ve found myself in the group that just turns them off these days. Fell out of the RGB fad.
I have one solid color with one of the wave animations at the slowest speed. I did this with both the gmmk, and gmmk 2. The gmmk was vertical waves, like waves on a beach, the gmmk 2 is side to side. I don’t like my rgb too busy honestly. I have done per key to highlight function keys in the past, but I don’t care for rainbow as the nicest way to put it as it’s frankly annoying. I actually dislike it when devices default to rainbow, and do not have a hardware profile so it requires the software be running to force that profile every time, and part of why I like glorious products, they can be programmed without software, along with being a linux user you basically can’t run windows software.
Now with the software running if you could do stuff like change the color to the cpu temp, or even a set of keys showing cpu usage/temp across the numbers/F keys that would be kinda cool. Like if a keyboard was wireles you could see the battery level by pressing a Fn key combo to see the 1-0 light up for the battery level, etc
With the trend in custom keyboards, and people buying non shine through keycaps argb isn’t a huge selling feature anymore too. I do however still like illuminated keyboards with shine through keycaps, and being able to change the color is nice.
My go to is the one where every press sets a wave of color towards the edges…feel like theres a name but I forget
My build is based on a botanical theme, so my rgb is meant to mimic a rainy forest aesthetic
I find myself switching around all the time. Sometimes I use RGB puke gamer mode, sometimes solid, sometimes off. Depends on my mood I guess. More options the better!
I like to mix it up. Sometimes I like a single colour on something like wave or breathing. My daughter likes to put on anything rainbow lol. I do wish core had the worm option. Where the colour races around the board like a centipede.
Currently I keep my Gmmk Pro off ![]()
I have cherry pbt milkshake keycaps which well, the led does shine through the colourful keycaps of the set. I think depending on the keycaps, a solid colour isnt bad
I usually just go for one solid color, but it depends. My GMMK Pro currently has a static rainbow effect because it has the Aura keycaps on it, but once the grapefruit caps show up, that will probably change to a solid color (or a different color wave) that compliments those instead. But I don’t generally care for anything animated, it’s too distracting.
I keep my GMMK 2 on either ‘Glorious’ mode or the one mode where each key is a different color and it changes every 1-2 seconds, reminds me of colored marshmallows from a cereal or something lol. But my LOTR custom keeb I keep that on a single color.
For me, it depends on my board theme. Here are my active/in-progress keyboards with backlighting:
| Keyboard | Theme | Backlight Pattern |
| GMMK Pro | E-White | Glorious (I know: it should be solid white, but I love the rainbow) |
| GMMK TKL | Cyberpunk | Solid (magenta) |
| GMMK Compact | OEM | Random colors on all keys (no fade) |
| GMMK Full | Midnight Rainbow | Solid (blue) |
| Drop ALT | Vintage IBM | Solid (green) |
| Keychron K2 | OEM | Solid (white) |
| Kenesis Freestyle Edge | OEM | RGB Wave (L→R) |
| Tiger 80 | TBD | TBD |
This is quite the collection! Thanks for the breakdown. Interesting to see what people prefer.
