my uncle came to visit me today and wanted to see my setup. My keyboard had been the newest edition to my setup to i disconnected it and handed it to him to hold. he gently lifted it up and down and when i went to play overwatch, the keyboard didn’t work. can anyone help me?
Edit: i figured it out guys, all i had to do was hold fn, and esc. then press f1, f3, f5
That happened to me this morning. It was barebones as I was waiting for parts. So I put in new stabs, I plugged it in after connecting it… and it worked. then I put the frame, switches and keycaps on… plugged it in and nothing. Unplugged it from keyboard, from aviator plug. Nothing. Then I went into the Core and updated the firmware and it would type but lights were off. After a bit the lights came back. I think it’s my cable I’ve had to finagle with any keyboard from day one with this cable.
I have had this happen to me before a few times and each time after plugging it in and the keys not registering, I have just Rest my Keyboard by holding FN+ESC then F1+F3+F5 for 10 seconds and that resets the Keyboard back to Factory Default
I think it’s the software. Flashing to QMK makes that issue go away. And if you swap your keyboards around a lot (ie unplug the GMMK), the problem will get worse.
