Model I2 always on
The LEDs on my wireless mouse stay on even when I shut down my PC. How can I make them turn off when I’m not using it?
Should be a on/off switch on the bottom.
If you’re not using Core 1.0, install it. Core 2.1+ doesn’t work at all with the I2. There should be a sleep timer in the settings you can use to shut the mouse off in a certain number of minutes.
Otherwise yes, the other commenter is correct, you could just switch the mouse off.
How’s your battery life so far?
