I just opened up my Model D Wireless I got from pre-order and the right mouse click is sticking really bad. If I fully press it down, it hangs for a second and makes a discreet sound.
Mine has the same problem. The left click is very crisp but the right click has a sticky thonk.
@Johnyxiade @skitz0r sorry to hear this is the case! Definitely send our support team a message or live chat with them and they can help take care of this for you.
Similar problem on my end.
Issue seems to have just resolved on its own. After using it a lot for a couple of days it seems to be acting completely normal now.
