Modders show us what you did/got: GMMK 3 Pro and Pro HE sound mods
For the GMMK 3 Pro and Pro HE modders out there show us what you did or got for your gmmk 3 pros to get your perfect sound. I’m not talking just things you can buy from glorious but the full gambit we see for all custom boards out there.
Share tips, tricks, pics and vids (of the work and/or sound when typing) of the mods you have done to make your baby sing the way you wanted it to.
For those new to modding, and little nervous, you can get the 3 pro and 3 pro he, built or barebones, for less than half the price when buying used, now, and that opens it up a whole host of new people who this might be their first board build. Many people don’t know the lingo of board mods so here is a list to help the newbies out there
Stabilizer and switch mods
  • Lubing: Applying lubricant to stabilizer wires and switch components to reduce friction and rattle.
  • Clipping: Trimming the excess plastic from the legs of certain stabilizers to prevent noise.
  • Band-Aid Mod: Placing a soft material, like a band-aid or foam, under the stabilizer housing to cushion the impact and reduce noise.
  • Holee Mod / Wrap Mod: Wrapping part of the stabilizer wire with a material such as dental floss or fabric to reduce ticking sounds.
Sound and feel mods
  • PE Foam Mod: Placing PE foam on the PCB (Printed Circuit Board) to create a different sound profile, often described as “thocky” or “marbly”.
  • Tape Mod: Applying layers of tape to the back of the PCB to change the sound, which is a simple and effective way to alter the acoustics.
  • Gasket Mod: Using gasket material, such as Poron foam strips, to mount the PCB and plate, which creates a softer typing feel.
  • Force Break Mod: Adding a thin strip of tape or other material between the case and PCB to prevent a “forced break” or creaking sound when the case is pressed.
  • Tempest Mod: A variation of the force break mod that uses tape on the case instead of the PCB.
  • O-ring Mod: Adding O-rings to the keycaps to create a softer landing and a quieter bottom-out feel.
  • Muffling: Adding materials like foam, clay, or even sand into the empty spaces of the keyboard case to dampen sound.
