Okay, you guys came to my aid for the keycaps for the up coming Zoom TKL build, now onto the switch recommendations as can’t make up my mind.
I created a poll with my current thoughts or ones I’m thinking about.
Kinetic Labs Hippo Linear Switches (own)
Kinetic Labs Moon V2 Linear Switches
GLORIOUS LYNX Linear Switches
Gateron Oil King Switches
Gateron Ink Black V2
Other Options List Below
0voters
I like Linear switches but also a fan of the a tactile switch like the Glorious Panda’s (using them on my GMMK 2 96% work keyboard), so a switch like Tecsee Purple Panda crossed my mind too.
There are just so many options and choices. Using the Glorious Fox’s in another build and I can always revert back to the AKKO Speed Silvers that aren’t in use but want something different for this new build.
Let me know your guys thoughts in the poll and or comments below. Thanks for the feedback, as I’m driving myself crazy with options
I’m not much of a linear switch person so I can’t personally recommend a switch, but I have a co-worker who is always talking about how great the Oil Kings are. He’s someone who finds fault in everything so if he says something is great, it must be a unicorn.
Regarding the Tecsee Purple Pandas: I have a GMMK Pro build with them installed. They are pretty close to the Glorious Pandas. The Purple Pandas have slightly less travel (3.0 mm vs. 3.2 mm), a slightly longer spring (15.9 mm vs. 14.9 mm) and slightly more stem wobble. The stem wobble is the most notable difference, but it’s pretty small.
I’m no TheraminGoat or anything, but here are my measurements between the Tecsee Purple Pandas and the Glorious Pandas:
Glorious Pandas
Stem Length
13.95 mm
13.70 mm
Stem Material
POM
POM
Stem Travel
3.0 mm
3.2 mm
Spring Length
15.9 mm
14.9 mm
Spring Type
Progressive
Linear
Spring Stiffness
67 gm-force
67 gm-force
I keep all of this kind of data in a Jupyter notebook because I’m a super nerd.
It was a tough choice, as I love both the Oil Kings and Ink Black V2s. The reason I voted Oil Kings came down to them being factory lubed and not requiring anything extra. Ink Black V2s will need lube and film, but I find them to a be an extremely nice switch once that is done.
So it comes down to factory-lube (that is actually decent) or lubing and filming yourself. I didn’t like the Lynx switch, and I’ve never used the Kinetic Labs ones.
Of the listed switches in the poll, I’d personally go for the Lynxes because I really enjoyed them. Very smooth, factory lube was actually pretty good, sounded good. Nice springs.
I recommend checking out the KFA Pink Robins, Gateron Cream Sodas and Milky Yellow Pros, and the Gazzew Linear Thocks (aka Gazzew LTs). Gateron Ink V2 Blacks are nice but are showing their age vs newer switches.
I’m currently using KTT Kang Whites V3. They’re exceptionally good and my new favorite budget linear. I do like Ink Blacks and Milky Yellows but I’m really vibing with these. Lil Shoosh on YouTube uses them in a lot of his “creamy” sounding builds.
I went with the Oil Kings and the Moon V2’s (as I wanted to try them out after watching Alexotos video with them for his Mode Eighty build). Picked up a new coil cable and Durock V2 Stabilizers while at it too.
