keyStroke "Home" and "End"
hi i use the “home” and “end” buttons pretty often so i like dedicated buttons for it. i never use pgup and pgdn so i changed these buttons. but i dont get why there isnt a dedicated home and end keystroke with in the software. between “other” why must i add this as numpad7 + shift and numpad1 + shift?
Are you using Core 2.0 or the original Core V1 version? There are some know issues with keybindings with Core 2.0. I would look to go back to the original Core and see if you are able to properly bind the keys.
Well, some months later, and on 2.1.4 this feature is still missing.
Now, I’ve worked in IT for too long not to point an important distinction here: I would not call this “issues with keybindings” when it’s not a bug and more of an oversight, as the buttons for “Home” and “End” are simply not there, while they were and worked fine on v1.
@Tempy … with version CORE 2.1.3.4, has the “Home” and “End” binding been fixed? It still sounds like the latest update hasn’t fixed this issue.
