I would like to buy the GLORIOUS mice.
Howevere, i realized that the only S/W for mice is for Windows.
So, Is there S/W to controll MICE for MAC O/S?
If not, if i set and save the settings on Windows, can i ues them on MAC with the settings stored inside the MICE?
For example) DPI, Macro, Debounce time, etc…
Hello @MungMungE. Your assumption is correct. If you configure the mouse on a Window’s machine, those settings will persist even if you move the mouse to another computer. I have a work computer that I can’t install software on. I configure my mouse on a different machine, then just move it over. The same should be for your situation.
