I just installed the GSV2 in my GMMK PRO
…and I can’t believe they cost ten bucks.
I bought the black barebones GMMK PRO about half a year ago and installed Durock V2 stabs after balancing the wires and lubing it.
They were better than the stock stabs, but it took A LOT of fiddling to get rid of the rattling. Shift, Enter, and Backspace were OK, but the Spacebar always felt weird. The rattling would come and go, so I don’t know what’s up with that.
A few weeks ago, I decided to buy the GSV2 on the Brazilian Amazon site. I paid about 10 USD for the kit + shipping + taxes.
I read a few reviews before installing them, and people always mentioned that you should apply a thin coat of lube. The 2U wires were perfect out of the box. I balanced the spacebar wire, used less lube than usual (Krytox GPL 205G0), and installed them. I didn’t even need to Holee mod or do anything else.
The GSV2s are quieter than the Durock V2s, which was a nice surprise. There’s zero wobbling and rattling, and I had no issues like keys getting stuck.
I’m not sure if they work this well with the polycarbonate plate or any other keyboard, but they’re excellent in a GMMK PRO with an aluminum plate.
10 USD (or 5 USD via Glorious Store for GMMK PRO owners) is incredible value for what you get. I wouldn’t have wasted money if I knew I could get better stabs for half the price of a Durock V2 kit.
So glad to hear you like them and they’re working so well for you!
