GMMK Pro lights not changing?
Hi,
I am trying to change my lights using Glorius Core and whatever I change in the app is not changing on the actual keyboard after I press save?
It is just stuck on white lights.
The keyboard seems to be working fine, I have tried a different usb port and tried powering off then on again.
Thanks.
Hello @3dRick and welcome to the forum! That is annoying that you are having trouble with controlling the lights. First suggestion I would have is to force a firmware update on your board. That should be found through the settings of the Core software. If the problem persists, I highly recommend reaching out Glorious Support. I hope that your issue can get sorted quickly.
Keep us posted on this. Hoping you can get your RGB goodness up in running soon!
