Disclaimer: I have been a longtime supporter of Glorious and its products, all of my gaming peripheral & accessory purchases of the past 3 years have been 100% their products. I have recommended their keyboards, mice, and accessories to all of my friends over this time as well. I really applaud their commitment to making quality gaming peripherals accessible, I sometimes even pretend that the numpad isn’t an over-priced aberration from their entire brand identity.
All that said, I am no longer using my GMMK Pro as my daily driver. The reason for this is because consistently the “A” key on my keyboard simply dies. I have replaced the switch a total of 4 times since I’ve gotten the board, thinking I had a bad switch at first but it has happened enough times now that I know it’s not a coincidence.
I’m not particularly hard on the “A” key more than any other key on my board, as a gamer I’d expect any sort of faulty things like this to happen to “W” or left Shift as they are constantly being mashed or held down but no, they are perfectly fine.
It’s so immensely annoying to have my KDA ruined in competitive matches because in the heat of the moment I cannot move left reliably and get killed in whatever game I’m playing. I cannot for the life of me figure out why this would be happening. Has anybody else run into this problem with their Original GMMK Pro?
Check the switch itself and make sure the pins aren’t somehow bent noticed this with my gmmp pro and boards I’ve modified to have more flex than intended.
It’s likely to be the metal contacts in the hotswap socket getting too loose.
If you want to verify, load up a keyboard tester (like the one at https://config.qmk.fm/) and hold down the key while wobbling it in the north/south directions. If the key display flickers, or only activates when you’re pushing it a certain way, then it’s the socket.
You can fix it by opening up the board and using a small needle to push the hotswap contacts back toward the switch pin from underneath the pcb. It may be fragile, so don’t apply too much pressure when bending it back.
Unfortunately this is kind of what I’m thinking too. Not that I suppose peripherals that get used daily should last forever, but when you pay a premium price for a premium product you would expect it to last longer than this. In the case of a glorious mouse, I wouldn’t be too upset, but the GMMK Pro is an enthusiast product, which you would assume would be enthusiast grade.
Having the exact same issue with my keyboard. Randomly the A key is going in and out when I’m playing and its infuriating. What is up with the quality control team at Glorious. Only had this keyboard for less than a year.
I would contact support, I’ve had to have mice replaced like 3 times before I got a unit that didn’t die in the first month but they were pretty helpful and I didn’t have to pay a dime.
Having similar problems myself on several keys intermittently but frequently enough not registering n including S, O, L and possibly others (Space used to be a bigger issue but the switch replacement helped in that case) - its very frustrating given that I’ve never had this kind of issue with a keyboard before and it wasn’t like this at the beginning. I thought perhaps it was switches having issues and replacing a switch would sometimes help, but not always.
This would make sense if it was an issue like jint mentioned, but really it feel like it shouldn’t be having these problems. I’ve been kind of living with it a long time now, occasionally replacing a switch and wondering if they were just going bad (these are the first times I’ve used Glorious Pandas ) but if its more than that and the socket, I wonder if support may be able to assist.
