So I’ve had my GMMK 2 96% for about a year now and then suddenly one of the rows particularly the asd row isn’t responding to the lightings I choose even when I turn off the RGB it still has RGB on that specific row.
Hello @jaykoobi! Welcome to the forum.
Sorry to hear you are having issues with with your 96%. That’s a bummer. The first thing I would try is forcing a firmware update of your board with Glorious Core to see if that helps.
Otherwise, I would recommend reaching out the Glorious Support to see if they can assist in getting this addressed. They likely will have some tricks up their sleeve to get you sorted. Keep us posted on what kind of progress you make.
