My kickstand for the GMMK 2 has broken someone must have pushed it down too hard or smt as one of the clips broke on the right kickstand. Where can I get a replacement? anyone have any ideas
They sell a replacement feet set on their website, here hopefully that helps you!
I’ll also add that I have found with the addition of a wrist rest I do not feel the need for the kickstand. So if you are having trouble finding a replacement part, a wrist rest my be able to salvage the situation.
If you don’t find it on the site, I would recommend reaching out Glorious Support to see if they might be able to help you out.
Thanks
Thanks for the idea!
