Glorious Model O Wireless (1st model) stuttering when Steam is up and Discord is running and focused window.
So like if I open up Steam and try to go to some settings or just trying to move the mouse cursor randomly while Steam is up, it stutters.
It also happens on Discord but I was able to resolve it at least in Discord when I turned on the Hardware Acceleration. I also did the same in steam but it’s still ‘randomly’ happening in steam.
So now I am just using it with it’s wire which sux honestly ![]()
Anyone else having this same issue? It just started to happen and this mouse is 2yrs old but still is working 99% fine even sometimes with wire, I hear the usb disconnect/reconnecting sound of windows but that’s rare. It just sux when it happens when you are gaming.
Nothing was changed aside from my location which my rig is kinda near our Wifi Mesh.
My full rig specs below:
CPU: AMD Ryzen 7 5700G 3.8-4.6GHZ 8-Core Processor [Core Performance Boost ON, Precision Boost Overdrive Advanced, PBO Limits Manual, PTT Limit 88W,TDC Limit 80A, EDC Limit 110, Curve Optimizer Negative all cores 30, Load Line Calibration Mode 5]
GPU: AORUS Geforce RTX 3070 Master 8G (rev.2.0)
PSU: MSI MPG A850GF Gold 850W 80+ Full Modular Power Supply MPG-A850GF
Motherboard: MSI B550m Mortar
RAM: Kingston Fury Beast RGB 16x2 3200Mhz Cl 16
Case: Lian Li Lancool II Mesh C ATX RGB-S Snow
Case Fans/Accessories: ID Cooling XF12025 TRIO 3 in 1 CHASSIS FAN ARGB, Thermalright TL-C12C CPU Cooling 12cm 1550rpm White ARGB Fans, Deepcool GH-01 RGB GPU Anti-Sag
CPU Air Cooler: Jonsbo HX7280 CPU Radiator Air-cooled Tower Computer Desktop 7 Heat Pipe Cooling Fan
Storage 1: Gigabyte Aorus M.2 1TB NVMe Gen4 SSD GP-AG41TB
Storage 2: Samsung QVO 1TB
Keyboard: Keychrone K4 V2 Gateron Brown Switches
MOUSE: Glorious Model O Wireless
Gamepad: Xbox Wireless Controller Stellar Shift Special Edition (Asian)
Headset: Logitech G PRO X Wireless Lightspeed Gaming Headset - Shroud Edition
Speaker: Edifier M1360 2.1 with Subwoofer Speaker
Condenser Mic: RODE Microphones NT1 Kit
Monitor 1: Gigabyte 24F 165hz 1ms IPS Full HD/1080p/1980 x 1080
Monitor 2: BenQ 24’ XL24111 Full HD/1080p/1980 x 1080 vertical ready
USB Wireless Adapater: Comfast wi-fi adapter 5ghz 802.11ac 2.4ghz dual-band wireles (directly connected to the motherboard)
UPS: CyberPower UPS VP1200ELCD UPS 1200VA/720W (usb cable for monitoring is connected directly to the motherboard)
