Hi,
I’m having a prroblem with some Glorious Lynx Lubed switches (which just happened while I was typing this on the “r” letter there). I’ve had about 5 switches start making doouble (gah again, ‘o’) actuations. I’m using a Drop CTRL barebones with these switches. The keyboard was fine on the last couple of switches I used, this has only happened with these lubed Lynxes. LOVE the switches but these double strikes are killing me.
I’ve replaced 3 switches so far and that has fixed the problem on those keys. But it’s also happening (with less frequency) on another 3-4 letters. So I’m going to replace thoose as well (‘o’ again, ugh).
Any suggestions? It definitely looks like the switches are to blame, because when I replace them then the problem stops. Is it the pre-lube or something? I’d rather not pull them apart. These were super expensive.
