So im confused. If i touch this pad and get my fingerprints on it will it slow down or effect the Quality of the glide also can i wipe it down with my hand or should i get a special cloth and how often should i clean it.
You want to avoid touching the Ice mousepad as much as possible, as it will absorb the oils from your hands and fingers. This won’t drastically affect the mousepad at first, but over time as those oils build up, it can affect your mouse sensitivity or glide. You should make sure your hands are clean anytime you’re using it, as they need a little bit of TLC to wash.
You can read cleaning instructions on the paper that came with the mousepad, or here!
Something like a microfiber cloth might not be a bad idea to keep around to help clean it up between uses as well.
I used the Elements Ice pad pretty heavily for about 5 months and it held up great.
I did run into an odd issue where the pad started to feel a little sluggish, but it turned out I just wore the PTFE feet on my mouse out. Swapped the feet and havent had any other issues. The glide has been consistent and Ive only needed to clean it once.
I bought each of the Elements pads to try out. Haven’t opened the Fire yet, but I do prefer the Ice over Air. I need to spend some more time with them for sure
I have a lint roller that I use to remove cat hair and whatever gets on my mouse pad. And I regularly vacuum it with a my handheld dyson vac. And every few weeks I’ll throw it in the washing machine. I know there’s arguments about whether to hand wash or not but I’m too lazy to hand wash lol
But yes, over time, it slowly slows down your sens. If you play a lot of FPS then I’d recommend cleaning them regularly. Once you clean it you’ll be able to notice the difference.
I feel like the Ice pad would be one you’d want to put through the washer and dryer the least, due to the infused glass. They recommend that you don’t roll it up, or anything like that.
Masking tape also works if you don’t have a lint roller
Someone on the forum suggested using glass cleaner on the Ice pad when I needed to give it a quick wipe down and it actually worked really well. Just a few sprays on a microfiber towel, a few circles around the pad, and it was dried off after like 10ish minutes.
ive just been using a damp microfiber to wipe it down real quick if i notice oils and stuff on mine. its only been half a week but i can say i like the ice pad the most out of them all. paired with my model o wireless and g floats, this thing literally feels like ice!
