Not sure if I’ve done something wrong, but with the mouse plugged in it works fine, but the RGB does not work? I ticked the box for seperate brightnesses and that had no results.
Thanks in advanace
Thanks in advanace
Never happened with mine. Try using another profile?
I wound up swapping the cable to a power-only USB plug on my hub (it has some that provide data, and some only for power) and that makes the mouse think its still wireless when I charge, and that solved the RGB. I will try another data enabled plug just to double check next time I need to juice the mouse up. I did try another profile, and that seemed to have no effect.
EDIT: After swapping ports it now works normally.
This topic was automatically closed after 433 days. New replies are no longer allowed.
