Glorious forge series one pro centauri, side buttons
Anyway, the problem is that yesterday everything was working fine, but then I inserted the mouse into another computer and the side buttons stopped working at all, both on 1 computer and on 2, I tried to fix it with software, but nothing works, any ideas what can be done in this situation, because I do not think that something could have happened to the mouse
I’ll be honest @FazZy, that’s a new one.
So as with any issues regarding a product, I always recommend reaching out to official support for troubleshooting. You can reach Glorious Support here!
In the meantime, you can try doublechecking the profile in CORE and make sure the buttons are actually bound to something. I’ve seen a lot of issues with CORE dropping key bindings recently.
Make sure you don’t have a firmware update or try reinstalling the firmware.
You can also try forcing a reset on the mouse. Hold down the left-click, right-click, and scroll-wheel (middle) buttons simultaneously for about 5 seconds.
You’ll see the LED (usually under the DPI button) flash, confirming it’s been reset.
Let me know if any of those work, or if support is able to help resolve the issue.
