A few years ago I picked up a set of LEDs for my desk from the brand Signal cuz RGB=Pretty. Well, I just went to configure my desk light, and my mouse started changing color. So I opened the app and sure enough, Signal RGB can now control glorious devices. You need to flash QMK to the keyboard tho so I don’t think ill bother. But it worked automatically on my model D and should on model O as well. It can control a bunch of other devices too so maybe check out Signal RGB if you’re sick of your current light options and want to sync your setup.
Interesting, thanks for the information
Flashing the keyboard isn’t really that hard and the result is absolutely worth it. Would love if they natively supported the devices though.
Exactly, would be cool to see if the glorious team can maybe collab on letting them do some native support rather than rely on QMK.
If these two companies partnered all other keyboard manufacturers would go bankrupt.
