I saw that with the AVX Works FR4 plate you don’t need to use the screws 8 screws (I think that is how many) that you take out when you replace the original plate with the FR4 plate, so I am wondering if the Glorious FR4 plate will be like that also. It seems to me that would make taking the GMMK Pro apart to mod or do whatever you need to do inside and then putting it back together a much simpler task
Can confirm it is easier. I use the avxworks one.
Cool, that is what I thought. Hopefully Glorious will do that with their FR4 plate
I would like the option to go screwless, but i would also like to have the option to at least use the 4 screws on the led defusers
Is this roadmap up to date? Seems like it’s sort of behind, I don’t think the August drops happened at all and none of the September ones have yet either.
Yeah, it is up to date for the most part. It does mention though that the dates are an estimate and may change at any time
