I am looking for a good set of linear switches for a 65% keyboard but I don’t want to spend more than $35. The keyboard will be used for gaming only and I would prefer pre-lubed.
Not quite $35 but it be hard press to beat these on Amazon for $41.
Akko CS Silver Lubed Switches - $20.99 x 2
You can always go with the trusty Gateron KS-3 Milky Yellows. They are factory lubed.
Would probably come in at half your budget.
You can find them here.
Vouch for these - love these switches as a budget switch.
My favorite budget linear is the KTT Kang White V3. A set of 70 is only $20. But they’re not lubed. I use these in my GMMK Pro.
