just bought model o wired and im having trouble syncing it with signal rgb it wont show up any suggestions?
What software are you using? The Model O wired does not use Core, it uses the older program to control RGB, etc.
https://www.gloriousgaming.com/pages/glorious-software?software=MODEL%20O/O-%20WIRED
im using the default model o software from the downloads page but it still wont show up on signal rgb it says no plugin
Signal only works with wireless Models O and D you can check supported devices here
Also Signal is not the default RGB control. Nor are they affiliated with Glorious as far as Iām aware. As @tecmo34 stated Glorious Software for the wired mice can be downloaded here instead.
Yes I know that I have both software I was just wondering if there was a work around for the signal rgb support
