Pro Straight Cable?
If Glorious had a Pro Straight cable that would be great! Anybody else?
I just realized that the cable on the site is called the Glorious Coiled Cable, so I suppose the name should instead be Glorious Straight Cable. I confused it with the CableMod ones because they use the “Pro” naming. I got some sleeved extensions for my PC and noticed they offer a straight cable as well as coiled which is where I got the idea.
I can imagine the outrage generated by the Glorious Straight Cable name… :laughing:
What do you mean? It’s a cable without a coil, so it’s a straight cable. CableMod does it, I don’t see why Glorious couldn’t.
It was a joke, because some words (in this case straight) will automatically trigger people…
