Bonjour,
Peut t’on synchroniser le rgb du gmmk pro + la souris glorious model D wireless ? Si oui , quel logiciel utiliser ?
Merci
Bonjour,
Merci
Hi @bene29, thanks for posting! I’m going to add a translation here as our support team and staff can only respond to questions in English. Please let me know if there’s anything off on the translation:
“Can we synchronize the rgb of the gmmk pro + the glorious model D wireless mouse? If so, what software should we use?”
hello
sorry I didn’t know… it’s ok for the translation
I use signal RGB and it supports both those peripherals. It’s super easy to use and there are a ton of customization options
It’s been a while since I’ve tried out Signal RGB. I should give it another shot!
